jawknee
Aug 07, 2011Aspirant
NV+ 2TB Limit - Was Disappointed, Now Happy
I bought an NV+ a couple of years back and was happy to see the improved support for Timemachine. But, with just 2 1TB drives I was limited to ~600GB. I did my research and settled on the Western D...
mdgm-ntgr
Aug 08, 2011NETGEAR Employee Retired
What Security mode are you using under Security > Security Mode?
Did you specify "options:tm" for the share?
Why are you setting the share as the user's home share? You can add a user, add a share and configure the share so that only that user has access to it via Frontview. That is the proper way to add users and shares.
When I was talking about using SSH that was in regards to editing the config file to include "options:tm" for an existing share you'd created via Frontview.
You may also need to copy the ".com.apple.timemachine.supported" file from /c/.timemachine/.com.apple.timemachine.supported and paste it in your new share for it to be recognised by Time Machine.
To auto mount a share on login, mount it and save the login details to the keychain then go to Command Menu > System Preferences > Users & Groups > Your User > Login Items, unlock the system preferences pane (if not already unlocked) so you can make changes and drag and drop the mounted share to add it to the list
