cmb991
Apr 25, 2015Aspirant
NV+ and 8TB
Hey I have 4 2TB drives for my NV+. When I try to boot them on it, it just keeps saying Kernal Panic. If I put in a single 288GB Drive, it boots fine. What is going on??
1 Reply
- vandermerweMasterI see from your previous posts that you have a NV+ v1 , is this the unit you are referring to?
What firmware is running?
Was the unit running normally with these disks before the kernel panic message? If so was there anything that precipitated this situation?
Were there any disk errors reported?
Have you checked all the disks using vendor tools?
Do you have a backup?
