rsinsheimer
Jan 19, 2014Aspirant
NV+ dead, now what?
I have a two-part question: My NV+ has died, probably the power supply. I shut it down before my last move, now it won't restart at my new location. So I have a couple of choices: 1) I have a...
mdgm-ntgr
Jan 19, 2014NETGEAR Employee Retired
Is your serial in this range?: http://www.readynas.com/forum/viewtopic.php?p=54911
1) If your NV+ is a v1 (silver chassis, runs RAIDiator 4.1.x or earlier) then yes. Update your NV to at least as new firmware as you were running on the NV+, then power down the NV, remove the disks (label order) and follow the migration procedure: http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
2) Newer models use a different RAID format. However you could try mounting the array in an ordinary x86 PC. Instructions for an X-RAID array from the NV+ v1 are here: http://home.bott.ca/webserver/?p=306
