rsinsheimer
Jan 19, 2014Aspirant
NV+ dead, now what?
I have a two-part question: My NV+ has died, probably the power supply. I shut it down before my last move, now it won't restart at my new location. So I have a couple of choices: 1) I have a...
rsinsheimer
Mar 11, 2014Aspirant
Yes. The problem is "just contact support" can be challenging depending on how good a job you've done keeping up your account. If your NAS is registered with Netgear it *should* be straightforward. Good luck! :^)
