soxfan11
Oct 06, 2011Aspirant
NV+ Disk Issues (support case 16862225)
Hello all, I have an older NV+ ReadyNAS with (4) 500 GB hard drives. Honestly it has been so long since I set it up that I don't really recall the exact configuration, but I am pretty sure I used ...
mdgm-ntgr
Oct 06, 2011NETGEAR Employee Retired
Please contact NetGear tech support (http://www.readynas.com/support). Edit thread title (subject of first post) to include your case number. Attempting to fix the problem yourself (particularly replacing disk 3 with another disk when you couldn't access your data) may have harmed the chances of data recovery.
Mutliple disk failures can happen (disks can and do fail at any time), so backups are important.
