soxfan11
Oct 06, 2011Aspirant
NV+ Disk Issues (support case 16862225)
Hello all, I have an older NV+ ReadyNAS with (4) 500 GB hard drives. Honestly it has been so long since I set it up that I don't really recall the exact configuration, but I am pretty sure I used ...
soxfan11
Thanks for the response. My ReadyNAS is out of warranty so I didn't think to open a support case with Netgear before attempting to fix the issue. I always thought with XRaid that you could have a bad / missing drive and the system would continue to operate OK, but maybe that is not always the case.
Point taken on the importance of backups, but at this point I typically use my ReadyNAS as a backup system and as a location for less important data. No hardship if I do lose the info, but it sure would be nice to be able to check out exactly what is on there before I give it up as a lost cause.
John
John
