soxfan11
Oct 06, 2011Aspirant
NV+ Disk Issues (support case 16862225)
Hello all, I have an older NV+ ReadyNAS with (4) 500 GB hard drives. Honestly it has been so long since I set it up that I don't really recall the exact configuration, but I am pretty sure I used ...
mdgm-ntgr
Oct 06, 2011NETGEAR Employee Retired
If you have a problem with multiple disks then RAID isn't going to help. Now if one disk that's having problems is repairable then there is some chance of data recovery. I believe NetGear offers data recovery services for a reasonable fee. However if the data isn't that important to you, I would probably just cut your losses, check the health of all your disks, replace the bad disks and do a factory reset.
