grevillea
Jul 24, 2014Aspirant
NV+ Failing Seagate disk #23579190
I have NV+ since Nov 2011, always on, used primarily for backup (time-machine style backup for windows). Four 2TB Seagate ST2000DL003 drives in XRAID - two are -301 with CC32 firmware and two are -...
mdgm-ntgr
Jul 24, 2014NETGEAR Employee Retired
Disk 2 has 752 reallocated sectors. It also has a current pending sector count of 24 and offline uncorrectable of 24 (for a healthy disk these counts will be zero) which show it needs to be replaced.
We would normally recommend replacing a disk when the reallocated sector count reaches 50 (though you could replace it sooner if you wish).
The reallocated sector count is growing very rapidly which is yet another sign it needs to be replaced.
2!!Wed Jul 23 04:00:05 EST 2014!!root!!Reallocated sector count has increased in the last day.\n\nDisk 2:\n Previous count: 0\n Current count: 32\n\nGrowing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
2!!Fri Jul 25 04:00:05 EST 2014!!root!!Reallocated sector count has increased in the last day.\n\nDisk 2:\n Previous count: 32\n Current count: 752\n\nGrowing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
