Plarg
Jun 19, 2011Aspirant
NV+ Power Supply Failure
Apparent power supply failure in my Readynas NV+. System appears to power up then becomes unresponsive even to power button on front of machine. Smell coming from machine. Part#/Model#: RNV2-S4-R4...
viffer1
Mar 30, 2012Aspirant
My NV+ power supply just died. I had the typical burning smell and I'm unable to power it on. I have a case open with Netgear support, however my NV+ does not have a serial number anywhere on it. There is nothing on the back or under it on the bottom. I can see where there is a field for the serial but there's nothing there. I am the original owner, bought it brand new back in '04 prior to Netgear acquiring Infrant. Any help would be great.
Thanks!
Thanks!
