Plarg
Jun 19, 2011Aspirant
NV+ Power Supply Failure
Apparent power supply failure in my Readynas NV+. System appears to power up then becomes unresponsive even to power button on front of machine. Smell coming from machine. Part#/Model#: RNV2-S4-R4...
jenifer1231
May 10, 2012Aspirant
" Answers of your question:
1) Power supply replacement is available but it depends on your hardware.
2) Yes, you can buy a new NV+ and install your drives to recover the files.
3) You should keep a backup of files, if you are worried about data loss. And then you can replace your disks.
http://www.backup-power.ca/vaccine_refrigerators.html
