robclarke411
Oct 04, 2013Aspirant
NV+ problems
Hi All, I'm having some strange issues with my ReadyNAS NV+. I have three of these units now and two NV+ V2 units and thought I knew them well but can't figure this out. First I got this error: ...
robclarke411
Hi mdgm, thanks for replying! I did a quick test using Lifeguard. I ran it on each drive and it took about 5 minutes for each one. Would you recommend that I run the extended tests then? Do these often uncover problems that the quick tests miss? Thanks for your help.
