robclarke411
Oct 04, 2013Aspirant
NV+ problems
Hi All, I'm having some strange issues with my ReadyNAS NV+. I have three of these units now and two NV+ V2 units and thought I knew them well but can't figure this out. First I got this error: ...
robclarke411
Ok, thanks for the advice. I'll post back with my findings. Do you think I will lose all the data though because I started a resync and then it crashed? Or can I just now identify the faulty drive using the extended tests and put all the functioning drives back in with a replacement for the faulty one?
