egeek
Aug 18, 2012Aspirant
NV+ (v1) PSU died
Hi ReadyNASians, So my faithful NV+ died a few days ago due to the PSU overheating. I was greeted with the familiar smell of melted PCB components and found my ReadyNAS powered down and unable to p...
mdgm-ntgr
Aug 18, 2012NETGEAR Employee Retired
egeek wrote: I did try a couple ATX 1.x PSU's to power up the NAS in the course of troubleshooting until I learned that ReadyNAS PSU's were wired differently.
There is a post somewhere on the forum about what you'd need to do rewire a standard PSU (do at own risk and only if you are comfortable with messing with stuff like that).
egeek wrote:
Is that service advisory still valid? I'm not so inclined to chase Netgear about it given the age of the unit, but am I entitled to any support for this anymore?
In the US, they still do the PSU replacement. I don't know about down here. It is up to each region division of NetGear to decide what they do in regards to this.
egeek wrote: My ReadyNAS's mainboard and drive bay card appear ok. Could I buy a replacement PSU (I saw some on Amazon) and expect it to work ok?
Yes, if the PSU is the only problem that would work fine. PSU replacement instructions are here: http://www.readynas.com/kb/faq/hardware/how_do_i_replace_the_stock_power_supply_on_the_readynas_nv
egeek wrote:
It looks like I will be in the market for a new ReadyNAS if the option above is not viable. Should i go with an NV+ v2 (or something better?) and will the drives from my old sparc NV+ slot in and gain access to the old array and data?
The RAID format is different unfortunately so you can't migrate your disks across to the NV+ v2 or any of the other current models.
