egeek
Aug 18, 2012Aspirant
NV+ (v1) PSU died
Hi ReadyNASians, So my faithful NV+ died a few days ago due to the PSU overheating. I was greeted with the familiar smell of melted PCB components and found my ReadyNAS powered down and unable to p...
May 10, 2013Guru - Experienced User
I'm glad it worked. The main issue for the perm solution is that you need to modify the back panel to let the cable through. And of course, you need to keep the power supply separate.
BTW, I tweaked your post so the picture is shown.
