skywalker1215
Feb 02, 2012Aspirant
NV+ V2 Disk Failure Detected (Case #17738357)
Hello everyone! I recently purchased the ReadyNAS NV+ V2. I was really excited about finally having a mass storage device on our network, but since setting it up, we've had nothing but problems. ...
skywalker1215
I haven't ran the official tools, but i'd checked the drives on a PC before installing them. They showed up correctly in my external enclosure.
It's currently resyncing and since i'd prefer to not blow up my data again, I'll wait til that finishes to run the tests.
Is there a way to run the Hitachi test on an external HD that is 3TB? The tool notes it doesn't work on 3TB or greater or on externals. I use a laptop so i can't just throw it inside :(
I'll test the seagate and WD when i can! I'm doubtful that they are bad since they're different brands and all brand new and all seem to be failing equally. But if they fail the test, i'll gladly take that as the reason i'm having problems since i'm at a loss otherwise.
I also updated the thread title with my case num.
Thanks for the quick reply!
