KillerPM
Oct 01, 2012Aspirant
NV+ v2 Loud Fan after Firmware Upgrade
After upgrading the firmware to 5.3.6, the fan in my unit randomly decides to go full blast. The disks and the unit always sit at around 40 deg c, but the unit decides that it is hot and blasts the...
KillerPM
Oct 03, 2012Aspirant
chirpa wrote: Would need to see process usage. One guess may be the Smart Network Genie software in 5.3.6 using more CPU, causing the temperature to raise, which in turn will cause the fan to spin up to compensate.
The Genie control point is a Java Virtual Machine. It should only be running if you've activated Genie. But I don't have a Marvell system to see how it really acts to know more.
I have it disabled anyway.
I don't really know why it does it. Like I said, it didn't act this way before the firmware update.
I just leave the device off when I am not using it. Its a pity I have to do this.
