KillerPM
Oct 01, 2012Aspirant
NV+ v2 Loud Fan after Firmware Upgrade
After upgrading the firmware to 5.3.6, the fan in my unit randomly decides to go full blast. The disks and the unit always sit at around 40 deg c, but the unit decides that it is hot and blasts the...
Banz
Oct 18, 2012Aspirant
I just got mine and it updated to 5.3.6 after I powered it on. I put 4 empty disk in there and it started building the xraid2. But it took 4.5 hours to sync the last disk. Is that normal? I thought since I deleted the volumes on the disk before I put them in, it shouldn't need so much time to build a parity on an empty raid? While it's building the temp fluctuate between 42 to 48 and I experience the same noisy fan as you guys. It goes up to 3k rpm and is quite loud but will drop down for a bit and goes back up again.
