KillerPM
Oct 01, 2012Aspirant
NV+ v2 Loud Fan after Firmware Upgrade
After upgrading the firmware to 5.3.6, the fan in my unit randomly decides to go full blast. The disks and the unit always sit at around 40 deg c, but the unit decides that it is hot and blasts the...
Banz
Oct 19, 2012Aspirant
Thanks for clarifying that.
WRT to the downgrade, do you know if I need to backup my settings before doing an downgrade to 5.3.5? Is it also as simple as just downloading the older firmware and uploading it via the web portal?
