KillerPM
Oct 01, 2012Aspirant
NV+ v2 Loud Fan after Firmware Upgrade
After upgrading the firmware to 5.3.6, the fan in my unit randomly decides to go full blast. The disks and the unit always sit at around 40 deg c, but the unit decides that it is hot and blasts the...
ablamboo
Oct 31, 2012Aspirant
FYI - I just went back to 5.3.5 (from 5.3.6) and the fan noise persists. Groan. I may go for a fan swap (I've heard of users going to Fractal Designs or Gelid Solutions fans) and bite the bullet with the warranty. It's just too loud, I can hear it from the next room. How did this get past QC?
Nov 2 update: I replaced the stock Magic fan with a Gelid Silent 6 92 mm fan and the fan noise is gone. It's a pretty easy swap, just two screws on each side to pull off the sides and four more to pull off the fan and bracket on the back. The Gelid comes with 4 rubber grommets which you can use instead of screws to hold the fan to the bracket. No noise, no vibration. It was $6 (retail) to buy the fan online, how much is NetGear saving by selling the chassis with that crap noisy fan?
