KillerPM
Oct 01, 2012Aspirant
NV+ v2 Loud Fan after Firmware Upgrade
After upgrading the firmware to 5.3.6, the fan in my unit randomly decides to go full blast. The disks and the unit always sit at around 40 deg c, but the unit decides that it is hot and blasts the...
aks
Jan 30, 2013Virtuoso
I have just purchased an NV+ v2 and two WD 1TB Red. I upgraded the unit to 5.3.7 (it came with 5.3.5).
The WD Red disks are almost silent. Initial sync took ~5 hours.
However, the fan is whining away with a low level noise that is just annoying. It is fairly quiet, but in a quiet room, I can hear it over my PC. I changed the stock fan on my Duo (v1) to a Fractal Design 60mm Silent Series for the same reason. The fan on my NV+ v2 is reported as spinning at 1365rpm and each disk temperature is 26 degrees C (it's not under any stress yet).
Is 1365rpm the lowest / normal?
Is there a fan control utility for the NV+ v2?
