KillerPM
Oct 01, 2012Aspirant
NV+ v2 Loud Fan after Firmware Upgrade
After upgrading the firmware to 5.3.6, the fan in my unit randomly decides to go full blast. The disks and the unit always sit at around 40 deg c, but the unit decides that it is hot and blasts the...
a_burger_with_f
Jan 30, 2013Aspirant
Have you tried to do an OS reinstall after updating?
do you get any temp errors or are the logs showing anything about the temp
Agent ID: 82015 NETGEAR ReadyNAS Support Engineer
Contact Information: http://kb.netgear.com/app/answers/detai ... txaw%3D%3D
(US/Canada) 1-888-NETGEAR (Option 4 for Technical Support) / (UK) +44(0)8448 75 4000
