hoppingdeth
Apr 13, 2013Aspirant
NV+ V2 Power Timer not working
Hi Guys New owner of a NV+V2 after using Duos for years. Great device, but having odd problems with the power timer. I have the timer set to come on at 7am and switch off at midnight, but it doe...
hoppingdeth
Apr 14, 2013Aspirant
Thanks for the suggestion mdgm. Tried that first thing this morning but it didn't change the behaviour I'm afraid. I set it up to come on half an hour after I did the update and shut it down, but the power timer didn't start it up. So it looks like the power timer is simply not working for me on start up or shut down.
Do you think it is faulty hardware? I've only had the server for about 2 months. Has anyone else experienced this kind of problem?
