hoppingdeth
Apr 13, 2013Aspirant
NV+ V2 Power Timer not working
Hi Guys New owner of a NV+V2 after using Duos for years. Great device, but having odd problems with the power timer. I have the timer set to come on at 7am and switch off at midnight, but it doe...
hoppingdeth
Apr 15, 2013Aspirant
Hi mdgm
Thanks for your help. Contrary to my reply, it does look like its working now. Shut down last night and started up this morning - ok.
bios_ver now says:
U-Boot 1.1.4 (Feb 6 2012 - 14:42:36) Marvell version: 3.4.27
Netgear version: Uboot-1_1_4-NetgearNV+V4-V1008 If U-Boot Endiannes is going to change (LE->BE or BE->LE), Then Env parameters should be overriden..
Thanks very much for your help.
bios_ver now says:
