bhata
May 03, 2015Tutor
NV+V3 Stuck in Resync?
My ReadyNas NV+ V3 notified me that "A SATA reset has been performed on one or more of your disks that may have affected the RAID parity integrity. It is recommended that you perform a RAID volume ...
bhata
May 03, 2015Tutor
I have some of the files backed up.
I know which one is the bad drive.
How should I proceed? Remove the bad drive? Hot remove? Should I power down?
-bhata
-bhata
