bhata
May 03, 2015Tutor
NV+V3 Stuck in Resync?
My ReadyNas NV+ V3 notified me that "A SATA reset has been performed on one or more of your disks that may have affected the RAID parity integrity. It is recommended that you perform a RAID volume ...
mdgm-ntgr
May 03, 2015NETGEAR Employee Retired
Well seeing you have started a resync that depends on what the resync is doing.
You could try powering down, removing the bad disk and then powering on and seeing if it boots fine and you can access your data.
