bhata
May 03, 2015Tutor
NV+V3 Stuck in Resync?
My ReadyNas NV+ V3 notified me that "A SATA reset has been performed on one or more of your disks that may have affected the RAID parity integrity. It is recommended that you perform a RAID volume ...
mdgm-ntgr
May 05, 2015NETGEAR Employee Retired
How have you configured the NAS to work with the UPS? Do you have a USB cable connected between the UPS and the NAS? The NAS should be shutdown safely.
The proper way to test this is to connect the NAS power supply to a wall outlet and some other device to the UPS (which doesn't mind being unsafely shutdown) to drain the battery then unplug the power to the UPS.
The NAS should handle unsafe shutdowns gracefully in most cases but that may not always be the case.
