bhata
May 03, 2015Tutor
NV+V3 Stuck in Resync?
My ReadyNas NV+ V3 notified me that "A SATA reset has been performed on one or more of your disks that may have affected the RAID parity integrity. It is recommended that you perform a RAID volume ...
bhata
May 05, 2015Tutor
Yes I did have it configured to work with the UPS and, because of past experiences with power fails, that is why I thought to try this to force a clean shutdown.
However, the NV+ must have been partially stuck. Although it responded when I removed the bad hard drive, it apparently did not handle the UPS messages.
