avpman1
Sep 25, 2014Aspirant
NVX Dead PSU need options - asap
Long story short, the PSU in my NVX died and I removed it anticipating Netgear would replace it since it's still under warranty until November 2014. Netgear support (live chat) is telling me: Warran...
mdgm-ntgr
Sep 25, 2014NETGEAR Employee Retired
avpman wrote: If I have to wipe data, settings,and everything then is there no difference to just buying any diskless ReadyNas and using my drives to start over?
Well if you don't currently have a good backup there is a difference.
Anyway how did you go with contacting support again re your failed NVX?
