avpman1
Sep 25, 2014Aspirant
NVX Dead PSU need options - asap
Long story short, the PSU in my NVX died and I removed it anticipating Netgear would replace it since it's still under warranty until November 2014. Netgear support (live chat) is telling me: Warran...
avpman1
Sep 26, 2014Aspirant
mdgm wrote:
avpman wrote: If I have to wipe data, settings,and everything then is there no difference to just buying any diskless ReadyNas and using my drives to start over?
Well if you don't currently have a good backup there is a difference.
Anyway how did you go with contacting support again re your failed NVX?
Fortunately I do have good backups. So migrating to another model might be the best option going forward. If I can't get NG PSU or get the RND4000 repaired then it's too dangerous to depend on. If it goes dead it just turns into a great big paper weight.
I logged a ticket and they closed it because they saw that I have been speaking with a technician (I had asked to have a supervisor call me when I wasn't getting anywhere with chat.) He's checking if an RND4PSU1-10000S is compatible with the NVX. And, if they have one they will sell me.
Do you have any suggestions for a new model NAS in which I can move my four 2tb drives to? I'm OK if they have to be wiped and reloaded. I have everything backed up on USB3.0 drives, which I'm hoping a new ReadyNAS would have USB3.0 ports.
Thanks for all your time.
