mulgar
Aug 14, 2012Aspirant
NVX won't power on - Confirm PSU problem? - #19272793
I've had my RNDX400E about 2.5 years, the other day I noticed it was powered down, so I pressed the "On" button but nothing happened. So I did a little bit of basic troubleshooting, tried a known good...
mulgar
Aug 23, 2012Aspirant
Okay thanks mdgm, that advice doesn't sound too encouraging :-)
Focusing on copying off my data at the moment. Right now it's up and stable but I'm pretty sure if I power it off it will cut out on boot up a few times before powering up properly.
The case I have is just for the RMA, so not sure if that would be tracked under that or they would open a separate case. I'll give them a call in the morning and see how things go.
As always - thanks for you replies.
