mulgar
Aug 14, 2012Aspirant
NVX won't power on - Confirm PSU problem? - #19272793
I've had my RNDX400E about 2.5 years, the other day I noticed it was powered down, so I pressed the "On" button but nothing happened. So I did a little bit of basic troubleshooting, tried a known good...
mulgar
Aug 23, 2012Aspirant
Okay, on the phone with Netgear and edited subject line with case number, they are expecting the chassis, I wonder if they even tested this RMA replacement properly I'm not having much luck here.
To give you some further information I discovered the following (also it's now running latest firmware 4.2.21): With no drives in the unit, attempting to boot up, the power cut out after 2-3 seconds. Attempting to boot up it came up fine (with "no disks detected error"), I left it booted up like that and didn't touch it, power cut out after about 7 minutes or so.
If this unit gets replaced that would be my 4th ReadyNAS in 2.5 years (the very first one I got was DOA).
