kcejo's avatar
kcejo
Tutor
Mar 15, 2019
OD_stub.exe Trojan Detected but Unable to Delete
I have a ReadyNAS 212 device with 2 6TB disks, for a total of 12TB of data.  I just upgraded firmware to 6.9.5.  I have a Windows 7 machine.
I was just looking at the Logs and noticed 1 Trojan and 2 other infected files, but don't see how to delete the files.  Here is what the Log says:
Mar 15, 2019 11:34:42 AM
System: Antivirus scanner found a threat ( Win.Trojan.Agent-1124515) in the file /root/.42/MITMf/libs/bdfactory/onionduke/OD_stub.exe. Please delete the infected file soon.
Mar 15, 2019 11:15:59 AM
System: Antivirus scanner found a threat ( Win.Exploit.CVE_2015_0005-1) in the file /usr/local/lib/python2.7/dist-packages/impacket/examples/ntlmrelayx/clients/smbrelayclient.py. Please delete the infected file soon.
Mar 15, 2019 11:12:16 AM
System: Antivirus scanner found a threat ( Win.Exploit.CVE_2015_0005-1) in the file /usr/local/bin/smbrelayx.py. Please delete the infected file soon.
I cannot find how to get to the Root file to delete the Trojan, nor can I find my way to the other infected files.  Any help would be much appreciated.
Ericka
  • StephenB's avatar
    These are on the OS partition, so you would need to enable ssh, and delete them from the linux CLI.
    These aren't part of the normal NAS install, so you probably have installed some apps.  Which ones?
    • kcejo's avatar
      kcejo
      Tutor
      I installed the Plex Media Server (for RN2xx) and VPN Server, but could easily delete those.  The VPN Server isn't even enabled, and has never worked, anyway, so I think I'll just delete that.
      I don't have Linux on my machine, can you give me more details on how to delete these files?  Sorry, but I'm really new to the server area.
      Thanks for the reply.
      • kcejo's avatar
        kcejo
        Tutor
         I just checked SSH and it is enabled, so if you could tell me how to delete the file, that would be great.  Thanks.
ProSupport for Business
