claykin
Jan 06, 2012Aspirant
Odd issue with Duo and LAN port
A client moved to a new office taking his Duo with him. He tried to connect to the LAN in the new office and the LAN port on the Duo would not show any signs of connectivity (no lights/LEDs at all at...
mdgm-ntgr
Jan 06, 2012NETGEAR Employee Retired
What version of RAIDiator is on the unit?
Have you tried an OS Re-install?: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
If that still doesn't fix it, if you power down the NAS and then boot it into tech support mode do any of the LAN port LEDs light up and is it seen in RAIDar (http://www.readynas.com/downloads)? Note it may take a few minutes or so before it shows. Don't leave it in tech support mode of course.
What about if you boot the disk normally with no disks installed?
