claykin
Jan 06, 2012Aspirant
Odd issue with Duo and LAN port
A client moved to a new office taking his Duo with him. He tried to connect to the LAN in the new office and the LAN port on the Duo would not show any signs of connectivity (no lights/LEDs at all at...
mdgm-ntgr
Jan 07, 2012NETGEAR Employee Retired
You might want to contact NetGear tech support (http://www.readynas.com/support) to see if they've had any other reports of a similar issue with the switch.
If you need to get a new switch I'd recommend getting one that supports IPv6.
