claykin
Jan 06, 2012Aspirant
Odd issue with Duo and LAN port
A client moved to a new office taking his Duo with him. He tried to connect to the LAN in the new office and the LAN port on the Duo would not show any signs of connectivity (no lights/LEDs at all at...
claykin
Jan 09, 2012Aspirant
StephenB wrote: Can you take the duo into the switch room, and try connecting it directly to the office switch port? I realize that the office port checks out ok on your tester, am just thinking that test would eliminate any possibility of something subtle with the wiring.
claykin wrote: I believe this is a hardware incompatibility problem. Odd thing is that at the other end of the cable is a GS116 Netgear Gigabit switch. One would think they'd make their NAS work with their own switch....
I did and it works OK directly connected to switch port using 6 foot cable.
Building cable checks out OK and works just fine with about 6 other devices I tried. Also checks out OK with my cable tester. The Readynas definitely doesn't like something with this office wiring. For now I have a switch in between which seems to have worked around whatever issue there is.
