nikbhatia13
Dec 03, 2015Tutor
Offline Installation
Hi , I got my Ready NAS 102 yesterday and now trying to connect and use it. My setup: 1. attached the hard disk in the storage bay 1 2. connected Ready NAS 102, using ethernet cable to the wirele...
- Dec 06, 2015
Hi Stephen,
Thank you very much for your exact pinpointing of the issue and i could figure out the solution also.
I was not able to connect my wired laptop to the wirelessly connected laptop due to a setting of Modem.
This setting is named 'Enable MultiAP Isolation'. It was on by default.
When i switched it off, i was able to make it work.
This solution resolved my issue related to NAS Drive as well.
Thank you so much.
Nikhil
