JeroenReadynas
Apr 22, 2016Aspirant
Only old Harddisks on Compatibility List for ReadyNas Ultra 6
Hi, I only see old harddisks on the Harddisk Compatibility List. For example from 2011 (3TB disks). Why not recent ones? The newest 4TB disks are: Hitachi 7K4000 HUS724040ALE640 - from mid 2012...
- May 11, 2016
Ok.
Just for anybody who wants to know my experience, I tried two kind of WD disks, and they both work fine in my NAS:
- WD20EFRX (the new Western Digital Red 2 TB)
- WD40EZRZ (the new Western Digital Blue 4 TB)
Bye,
Jeroen
mdgm-ntgr
Apr 22, 2016NETGEAR Employee Retired
The Ultra 6 is EOL and has been discontinued for some years now. There will be no more firmware updates for it and we won't be testing any more drives with it (some drives not on the compatibility list might work, but if you run into issues support may be denied).
It sounds like there probably is a problem with that disk. The disk wouldn't fail the SMART test for no reason. The SMART test checks the health of the disk. Disks can be D.O.A.
Have you hooked the disk up to your PC and tested it using WD Data LifeGuard Diagnostics?
Btw The WD RED are recommended for NAS use. Why did you choose the WD Blue over these?
You can run ReadyNAS OS 6 on the Ultra 6 but this is unsupported.
- StephenBApr 22, 2016Guru - Experienced User
Just to clarify - the ReadyNAS doesn't check the disk models against the compatibility list. It is likely your drive was DOA, so you should test it on a PC with WDC's lifeguard to confirm. Or just exchange it (ideally for a Red).
Blues are the "new" WDC Greens - not the same as the Reds. http://techreport.com/news/29251/western-digital-paints-its-green-hard-drives-blue-in-rebranding The Reds might be a bit more, but they also have better warranties.
- JeroenReadynasApr 22, 2016Aspirant
Thank you for your quick response!
You were right: it's a DOA. Althought the Smart statistics looked fine, the test wasn't:
Test Option: QUICK TEST Model Number: WDC WD40EZRZ-00WN9B0 Unit Serial Number: WD-xxxxxxxx Firmware Number: 80.00A80 Capacity: 4000.79 GB SMART Status: PASS Test Result: FAIL Test Error Code: 06-Quick Test on drive 3 did not complete! Status code = 07 (Failed read test element), Failure Checkpoint = 102 (Unknown Test) SMART self-test did not complete on drive 3! Test Time: 16:57:52, April 22, 2016 About Red and Blue (which is the new Green): I mean the hardware = stuff inside is the exactly the same; only the firmware is different. (And probably a vibration sensor.)
I don't see an advantage for a Red: TLER is not better for software RAID and the price is much higher for the Reds. One more year warranty is an advantage indeed.
But that's my opinion.Thanks for the advice,
Jeroen- StephenBApr 22, 2016Guru - Experienced User
I've seen other people assert that the hardware isn't the same, but there's precious little real information.
On vibration, one assertion is that the reds simple vibrate less than the greens (and don't have better protection) - which of course could be a difference in manufacturing tolerances. The spec on acoustic noise is 3 db lower with the Reds, which is consistent with less vibration.
