tim_t
Dec 18, 2018Aspirant
Operate RN428 on its side?
Hi!
I recently purchased a RN428 for personal media storage, for the past few weeks it has been doing its job nicely standing under my desk, however due to fan/disk noise I want to move it to a sep...
Dec 18, 2018Guru - Experienced User
Orienting it sideways shouldn't cause any problems. But putting it in a cupboard might - there needs to be good air flow. That includes having reasonable space above the air vents on the side of the unit, as well as in the rear. An open shelf would be a better option.
If you try it, then I suggest putting the NAS under load in it's current location, and note the temperatures and fan speeds you are seeing. Then do the same test in the new location, and make sure the temps and fan speeds are about the same. You can use NAStester to create the load ( http://www.808.dk/?code-csharp-nas-performance ). I'd run it for a while (15 minutes or so).
tim_t
Great to hear that, thank you!
Temperature/Airflow should be OK there is plenty of width and depth available and the cupboard is also well ventilated since its housing other electronics...
// edit:
good point about the hinges roland! I will keep it as is for a few more days and note some temperatures to compare afterwards. While I am not completely convinced that the 'heat moves upward' argument is applicable in this case, its nevertheless interesting how/if this influences temperature...
- StephenBDec 18, 2018Guru - Experienced User
Heat does of course flow upwards. I think it's quite important to put the side vents on the top. The ensures that the CPU fan can do it's job. If the hinges aren't in the correct position, then perhaps hold the door in place with a bit of tape.
- SandsharkDec 18, 2018Sensei
Actually, heat does not flow upwards. Hot air does. In a forced air situation, as in the NAS, convection barely has an effect. But you still want the vents up unless the shelf is vented because you do not want the shelf to impede the forced air flow. Sufficient surrounding space or forced air ventilation of the cabinet are needed to insure the exhaust isn't directed to the intake
- Retired_MemberDec 18, 2018
Sandshark wrote "Actually, heat does not flow upwards. Hot air does."
Just for the records, operating the nas on the surface of a planet being exposed to gravity heat does flow upwards, because hot air does :-)
But you are absolutely right, that "In a forced air situation, as in the NAS, convection barely has an effect."
