TT_DE
May 29, 2019Luminary
OS 6.10.1 - remarks wrt GUI
Just installed 6.10.1. - works so far. Just a few remarks towards the GUI: Available capacity in the shares area is missing (see pic 1) system page, available space graphics at different height (...
May 29, 2019Guru - Experienced User
TT_DE wrote:
- Available capacity in the shares area is missing (see pic 1)
Check the volume settings wheel and make sure that Quota is enabled.
- schumakuMay 29, 2019Guru - Experienced User
StephenB wrote:
TT_DE wrote:- Available capacity in the shares area is missing (see pic 1)
Correct. Available and Consumed space here is only shwon woth the Volume quota enabled (and reasily calculated/counted/built).
- TT_DEMay 30, 2019Luminary
I remember that the capacity was shown without having set quotas with earlier firmware version but I might be wrong.
- StephenBMay 30, 2019Guru - Experienced User
It always required quota to be set - otherwise btrfs won't supply the information.
I'm thinking you did an OS reinstall recently, as one side effect of that is turning quota off.
