TT_DE
May 29, 2019Luminary
OS 6.10.1 - remarks wrt GUI
Just installed 6.10.1. - works so far. Just a few remarks towards the GUI: Available capacity in the shares area is missing (see pic 1) system page, available space graphics at different height (...
May 29, 2019Guru - Experienced User
TT_DE wrote:
- Available capacity in the shares area is missing (see pic 1)
Check the volume settings wheel and make sure that Quota is enabled.
schumaku
Correct. Available and Consumed space here is only shwon woth the Volume quota enabled (and reasily calculated/counted/built).
- TT_DEMay 30, 2019Luminary
schumaku wrote:
StephenB wrote:
TT_DE wrote:- Available capacity in the shares area is missing (see pic 1)
I remember that the capacity was shown without having set quotas with earlier firmware version but I might be wrong.
- StephenBMay 30, 2019Guru - Experienced User
It always required quota to be set - otherwise btrfs won't supply the information.
I'm thinking you did an OS reinstall recently, as one side effect of that is turning quota off.
