Sandshark
Oct 16, 2017Sensei
OS 6.9.0-RC1 warning about dissimilar drives
One of the drives in my "sandbox" system (Pro2 with latest beta, currently 6.9.0-RC1) died (I use ones with higher SMART errors removed form other systems, as much as anything to see if the new OS versions handle them well) and I replaced a 7200RPM 2TB drive with a 5900RPM one. I got a warning from OS6.9.0-RC1 about using dissimilar drives, recommending I replace the 5900RPM one with another 7200RPM. I know I have mixed drive types in the past and did not get this message, but I don't recall what OS version(s) I have done it under. I have never seen anything before warning about this and, in fact, have seen posts in this forum that it's not a problem. I may have given that advice myself. Is there some new compatibility issue with the firmware, or maybe the newest hardware, that caused this to be added? Or maybe some of the lost volume issues reported here (way too many for supposedly stable OS releases, IMHO) have caused Netgear to re-think their position? Is this warning going to be added to the documentation?
- bedlam1Prodigy
Interesting, I replaced 2 of 4 7200rpm 2tb drives with 2 5980rpm 4 tb drives under ReadyNASOS 6.9.0-T62 (Beta 2) on my Pro 4 a couple of weeks back.
No warnings were given, now on ReadyNASOS 6.9.0 (RC1) and all is well (still)
- SandsharkSensei
Maybe more critical in a RAID1 than a RAID5? I may have never done this in a 2-bay unit.
- mdgm-ntgrNETGEAR Employee Retired
With disks with dissimilar speed you're limited by the speed of the slowest disk. You can mix and match drive speeds but it's obviously not the ideal configuration.
I guess this may start to have more of an impact once you start using features like SSD tiering.
