garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
xeltros
Sep 04, 2014Apprentice
Why don't you see by yourself ? Netgear has a VM for that ;)
http://apps.readynas.com/pages/?page_id=143
This VM fully works for virtualbox. My ESX server boots it with LSI SAS driver but the interface for drives volume is showing only one disk, so you can't test the raid modes.
You can update the VM to the latest software if you want, it should work.
I don't have a NAS with a 4.x version to give you more detailed informations, but I think/hope the VM will give you every answer you need.
