garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
Sep 04, 2014Guru - Experienced User
I do have checksums enabled but haven't seen performance issues. I am running jbod, not raid - which could matter. Though another recent post suggested that the checksums might actually not turn off, no matter how the GUI is set.
I started with the SFV files years ago when I lost a main disk and then discovered that the backup (optical) had read errors. Being able to verify the data if I wanted to seemed like a good idea going forward. It'd be hard to do on the photos and documents, since they aren't as regularly organized. But the audio and video libraries are (one folder per album, etc), so I just make them as I rip things.
I have antivirus turned off. The PCs have AV protection, so I don't see the need for it. And on the ARM the performance penalty is significant.
File system compression is another OS6 feature that OS4 doesn't have. I don't have it on though (it helps for documents, but not media that is already compressed).
