garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
mdgm-ntgr
Sep 06, 2014NETGEAR Employee Retired
garyd9 wrote:
It might take a few years for the volume to get out of degraded status. For some reason, I decided to stress the thing out by copying a few hundred GB's of data to a newly created share while it's still rebuilding the array. (On the other hand, I have to admit that I'm impressed that I'm getting 75MB/sec copying to the degraded array while it's rebuilding!)
Please note that the resync is a low priority process. However your volume is redundant throughout this time in the sense that if a few disks fail your data remains intact. Obviously copying data while the array is rebuilding will slow the process a bit.
garyd9 wrote:
For some reason, "Apps->Available Apps" is completely empty for me (and refresh does nothing.) I'm not sure if that's because the hardware is unsupported, or if it relates to deleting and re-creating the volume when getting RAID6 + XRAID active. (Actually, it can't be the hardware, as there was stuff listed there the FIRST time I booted OS6 after a factory default. I've done a couple of factory defaults since then, but I don't remember when they list became empty...)
That could be due to incorrect network settings. Do you have Genje Apps enabled? If so try disabling that.
