garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
garyd9
Sep 06, 2014Virtuoso
No, genie is disabled. (I did try enabling it at one point to see if it would help, but no luck, so disabled it again.) I _can_ upload .dep files, but dependencies aren't being installed automatically. (Example: I downloaded the transmission package from "http://apps.readynas.com/pages/?page_id=9", and uploaded it.. .but it didn't work. apt-get showed a missing dep of "transmission" for "transmissionr6"
mdgm wrote: That could be due to incorrect network settings. Do you have Genje Apps enabled? If so try disabling that.
I dropped to SSH and noticed that "apt-get update" is giving a PGP (er.. GPG error: "W: GPG error: http://apt.readynas.com 6.1.9 Release: The following signatures were invalid: BADSIG B7F02108D553259A RAIDiator Release Key <admin@readynas.com>") No idea if that's related or not.
