garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
mdgm-ntgr
Sep 06, 2014NETGEAR Employee Retired
Ah.
That repository might have been updated recently and the changes can take a little while to propagate through.
If that isn't fixed by Monday (i.e. If an apt-get update doesn't work then) let me know.
Which 6.1.9 RC are you running?
