garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
mdgm-ntgr
Sep 06, 2014NETGEAR Employee Retired
Due to important fixes in 6.1.9 RCs such as one relevant to doing a factory default (which is required as part of the R4toR6 upgrade process) I chose to update that to update to upgrade to 6.1.9 RCs.
When you SSH in you should see which RC you are running.
It would also show in the logs in os_version.log
