garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
garyd9
Sep 06, 2014Virtuoso
@mdgm, unless you have a suggestion (or something you want me to try) in the next few minutes, I'm going to factory default (again) and reconfigure the array (as described above)... and then get some sleep while it rebuilds.
