garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
mdgm-ntgr
Sep 06, 2014NETGEAR Employee Retired
Have you tried rebooting?
Have you tried disabling AV?
Note apps and dependencies won't be able to be downloaded till the changes to the apt-get repository are propagated.
You could try changing the sources list to use e.g. the 6.1.8 one as a temporary workaround but some things in that repository might not work well on 6.1.9.
