garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
mdgm-ntgr
Sep 06, 2014NETGEAR Employee Retired
Not sure.
Did you manage to install anything?
You could try removing packages you installed to see if that helps or better yet install them over the top of themselves once the apt-get repository is fixed.
